Votlage Supplies (kinda BS2 "?" )
I will be soon posting a "OMG help me" thread, but for now, I have a basic question about voltage supplies. Apologies if this is too off-topic.
I need to run the BS2 with its voltage source. I am using this to control a servo, and then a stepper motor. I can't run the servo off of the board due to the current draw and reseting the stamp. The stepper needs 12V. So I have 3 devices to power, but I have a small space.
Is there a way to double-team a power supply so it can give the 5volts and 12 volts, so I don;t have to cram 3 battery packs or power supplies into this thing? Servo and Stepper will never run at the same time.
Also, if I have a pin outputting a constant voltage (signal turned high), will that affect at all signal output for a servo or stepper motor?
Thank you all for any help.
-Newbie
-Newbie
- Stephen
thanks for the feedback, y'all.
- Stephen
