Transistor or Relay?
Hi, I recently built an led lighting system in my room. The led's them self are all individually controlled and connected with a common cathode. Because of their power demands I cannot drive them off of the stamps current and voltage, thus I need to use a transistor but not a BJT. I tried using a mosfet transistor to switch the lights on and off but I didn't realize that mosfets can only switch to ground which does not help me control lights with a common cathode. Is there a way to get around this problem?Possibly a diferent type of transistor, or am I going to have to use an expensive solid state relay for my application?
-Jacob
-Jacob
Here's a P-channel switching MOSFET from Jameco: www.jameco.com/Jameco/Products/ProdDS/256057PHILIPS.pdf
Post Edited (Mike Green) : 4/7/2008 5:56:09 PM GMT
