SERIN command help - reading a specific BIT
Hi all,
I'm fairly new to using a STAMP (to control things other than simple relays).· So, this has me a bit stumped.
I need to read specific data from a serial stream.· In other words, how would the SERIN command be set to read the value of BIT1?·
I tried doing something like,
Rad_dat var BYTE
Rad_bit·var BIT
Rad_bit= Rad_dat.BIT1
And, then DEBUG it to see the value.· (Once I see the value, I'm pretty sure I can take it from there.)
I'm just not geting it.
Thanks!
Rad_dat var BYTE
Rad_bit·var BIT
Thanks!
By the way, if you add DEBUG statements, you will miss some of the incoming serial bytes
because the Stamp will be busy for a time sending the debug information to the PC and it
can't do two things at once.
1) You need to receive from the serial stream one byte at a time with: SERIN <pin>,<Baudmode>,[noparse][[/noparse]Rad_dat]
Read the chapter in the Basic Stamp Manual on the SERIN statement for details and examples.
2) You need to refer to bit 1 of the data byte. You can just use "Rad_dat.BIT1" as you've shown or you can
copy the value to another variable as you've also shown ("Rad_bit = Rad_dat.BIT1").
