Vmusic2 Messages
Hi all !
I'm still playing with a vmusic2 module to get a full and improved mp3 player, well, although I've posted a code for an mp3 player, I found too dificult to manage the vmusic messages.
I've tried looking at the Mike's "Prism project" but I can't really get good ideas from that code (seems to be more complicated for me).
My original code manage the vmusic messages in a repeat loop, waiting for a byte recieved through serial port, .......that works, but I can't add more messages in the display at any time, because the rx loop is waiting for the vmusic messages.... (I hope you understand me ...what I mean).
I'm trying to controll now the vmusic using the handshake signals....to see if it lets me to modify my code and take more control of the data recieved (or the eactly time of it)...but I can see, that the "RTS out" in the vmusic, never changes the logic state, and also I can't found info about this, in all the vmusic & firmaware documents....
I suppose that Mike is the most experience with this module, but if somebody more have more suggests or experiences, I will be thanks this.
The exactly question is: How to ??? manage the vmusic messages and How to ?? use correctly the handshake signals.
Thanks all in advance !!
Regards.
Alberto.
Regards.
Alberto.
Yes, the Prism project routines are fairly complicated because they are designed for two VMusic2 modules operating simultaneously with a shared status display. Try stripping out all of the code for the parts you don't need. You need the modified FullDuplexSerial object and a simplified VMusic2 object. I didn't find a need for the handshake lines. The RTS line is only to stop the Propeller from sending to a busy VMusic2. The FullDuplexSerial routines are fast and buffered. I increased the buffer sizes to 64 bytes which takes care of the largest command and status response I expected.
Look particularly at playTheFile and the routines it calls. You'll see that, after sending a command to the VMusic2, it receives all characters until a timeout occurs, then looks for a match at the end of the buffered text. Most responses end with a specific prompt sequence and that's what is looked for.
I will try all you commented .
Regards.
Alberto.
I've stripped out most of the unneeded methods and modified a couple of them.
I haven't tested it, but look through it. It should be much more understandable.
I include the program here. It doesn't work to try to attach the file:
' VMusic2 Driver for Prism Project CON Cr = $0D ' New line / Return Lf = $0A ' Line feed Del = $7F ' Delete cmdChDir = $02 ' Change directory cmdOpen = $0E ' Open file for reading cmdRead = $04 ' Read file cmdClose = $0A ' Close file cmdDir = $01 ' Directory listing cmdPlay = $1D ' Play file cmdStop = $20 ' Stop plays maxLine = 80 ' Maximum line / pattern length maxTime = 100 ' Maximum time for VMusic2 response OBJ ser : "FullDuplexSerialMod" ' Serial link to VMusic2 VAR byte line[noparse][[/noparse]maxLine] ' Input line buffer (from VMusic2) byte lineLen ' Current length of input line buffer DAT echoUp byte "E",Cr,0 ' Upper case echo command / response echoLow byte "e",Cr,0 ' Lower case echo command / response chkStat byte Cr,0 ' Check drive status command longSCS byte "SCS",Cr,0 ' Long form SCS command shortUp byte cmdChDir," ..",Cr,0 ' Short form change directory upwards shortOK byte ">",Cr,0 ' Short form normal response shortND byte "ND",Cr,0 ' Short form No Disk response shortCF byte "CF",Cr,0 ' Short form Command Failure response stopMsg byte "S>",Cr,0 ' Stop play message PUB start(TxD,RxD) ser.start(TxD,RxD,%0000,9600) ' Start the serial port ser.str(string(cmdStop,Cr)) ' Try forcing a stop command repeat until cmdResp(@echoUp,@echoUp) ifnot cmdResp(@echoLow,@echoLow) ' Send "E" until we get a response abort string("Missed 'e'") ' then send "e" and check for echo ifnot cmdResp(@longSCS,@shortOK) ' Put VMusic2 into short command mode abort string("SCS not OK") if cmdResp(@chkStat,@shortND) ' See if a drive is present abort string("No Disk Present") ifnot endsWith(@shortOK) abort string("Status Not OK") repeat while cmdResp(@shortUp,@shortOK) ifnot endsWith(@shortCF) ' Make sure current directory is root abort string("Can't CD Root") PUB stop ser.stop ' Stop the serial port PUB playMusic(theDirStr, theFileStr) | t if theDirStr ' Check for a directory change ifnot setDirectory(theDirStr) ' Change to requested directory abort string("CD File Error") if (t := playTheFile(theFileStr)) <> true abort t if theDirStr ' Check for a directory change ifnot setDirectory(-1) ' Change back to root directory abort string("CD Root Error") PRI clearLine ' Clear input line lineLen := 0 PRI cmdResp(cmd,ans) clearLine ser.str(cmd) ' Transmit command repeat while bufferFill ' Fill buffer return endsWith(ans) ' Return match to response PRI endsWith(str) | s if lineLen == maxLine ' Is there room for a zero terminator? return false line[noparse][[/noparse]lineLen] := 0 ' Put it in s := strsize(str) ' Get length of pattern if s > lineLen ' Make sure input is long enough return false return strcomp(str,@line+lineLen-s) ' Return result of string compare PRI bufferFill | c ' Attempt to read a new input character if lineLen < maxLine ' Don't read a character if buffer full if (c := ser.rxtime(maxTime)) => 0 line[noparse][[/noparse]lineLen++] := c ' Save new character in buffer return true PRI endNumber(pos) ' Get 4 byte value relative to end of buffer repeat 4 result := result << 8 | line[noparse][[/noparse]lineLen-(++pos)] PRI playTheFile(theFileStr) | timeout clearLine ser.str(string(cmdPlay," ")) ' Initiate playing of a track ser.str(theFileStr) repeat while bufferFill ifnot endsWith(theFileStr) ' Response should end with track name return string("No Track Play Error") clearLine timeout := 0 repeat while timeout++ < 20 ' Timeout if no response in 2 seconds repeat while bufferFill if endsWith(@stopMsg) ' At end of track ... "S>" return true if endsWith(string(Cr)) ' Otherwise, it's two bytes with time timeout := 0 ' Reset the timeout return string("Timeout Play Error") PRI setDirectory(theDirStr) clearLine ser.str(string(cmdChDir," ")) ' Change directory if subdirNo < 0 ser.str(string("..",Cr)) ' Either go up one level else ser.str(theDirStr) ' Or use a specific directory repeat while bufferFill return endsWith(@shortOK) ' Make sure response is OKYour code was a big help for me, to understand more the vmusic !!
I also discovered that the RTS line only activates when you send "Disk" commands... but not when vmusic ones are sent.
Anyway I didn't use the handshaking.
Regards.
Alberto.
