how to control a continuous servo using PSC
Hi all, could anybody help me regarding the above matter.
I am new with PSC. I do have the manual from parallax for this PSC
but it shows only for the standard servo(180 degree).
I only have continuous servos, and I want them to operate between
0 to 180 degree...
Regrads,
Penang
0 to 180 degree...
Regrads,
Penang
You need the std servo..
The continous servo you have behaves like a dc motor...
ron
If I am not mistaken we can control the position of a continuous servo using BOE but I cannot use it. I have to control
5 servos at a time. Therefore, I need PSC.
None of the above. What it means is that a continuous rotation servo has no limits, and thus is not limited to a range of 0-180 degrees. A continuous rotation servos does just what it says it does, it continually rotates when energized by the signal pulse.
If you need to use 5 servos, the PSC is a fine controller, but it WILL NOT limit your continuous rotation servos to only 180 degrees.
Bruce Bates
Involvement and committment can be best understood by looking at a plate of ham and eggs. The chicken was involved, but the pig was committed. ANON
