Bracket Making ?
Im still at the gathering stage for my robot. I have servos, and the controller....But Im not sure where to start with the brackets.
Are there any cheap/easy solutions for brackets to connect the servos ? IVe been to the lynx site and find that their brackets are quite expensive and do not fit my needs.
I thought about getting an erector set but those are made of steel for the most part and will be too heavy. Ill be using dynam 8g micro servos.
I keep coming up short on google looking for brackets or something close that will fit my needs. I do not have any hi end metal fabrication tools. Just hand tools.
I am unsure If I am going to make a Quadro ped or Bi ped. So I would like to have options and some brackets that would be useful in several different configurations.
Does someone have hints, tips , or web sites that would help with my bracket debacle ?
Post Edited (El_Rage_O) : 4/7/2008 6:21:58 AM GMT
I've had some good success buying some stock anluminum "L" angle and cutting and drilling using common hand tools. You can find it at any Lowes or Home Depot, or on-line at http://www.onlinemetals.com/merchant.cfm?id=61&step=2&top_cat=60
