eb501 to eliminate the serial cable
does any know of any information about using the eb501 to eliminate the serial cable on a homework board?
also, where can i get information about how the homework board uses rs232? i have read that it is not standard so the eb501 can not be used for programming. i'd really like/need to go wireless i also have no appmod!
any help appreciated!
2) Yes, you can use an AppMod without the AppMod connector. It just supplies operating voltages (Vin, Vdd, Vss) and the 16 I/O pins. You can run jumpers to connect an AppMod device to some other board. Look at the schematic for the BOE.
This job would be a lot easier if I could type.
