PSM Bit Bang Timming Help
hippy
RxPasmLoop waitpne rxPasmPinMask,rxPasmPinMask
waitpeq rxPasmPinMask,rxPasmPinMask
mov rxPasmTimeout,rxPasmBitTime
shr rxPasmTimeout,#1
add rxPasmTimeout,rxPasmBitTime
add rxPasmTimeout,CNT
sub rxPasmTimeout,#K ' <---- HERE
mov rxPasmBitCnt,#8
RxPasmGetBit waitcnt rxPasmTimeout,rxPasmBitTime
test rxPasmPinMask,INA WC
shr rxPasmBitSeq,#1
muxnc rxPasmBitSeq,#$80
djnz rxPasmBitCnt,#RxPasmGetBit
mov txPasmTimeout,txPasmBitTime
add txPasmTimeout,CNT
add rxPasmTimeout,#K ' <---- HERE
TxPasmSendBit shr txPasmBitSeq,#1 WC
muxc OUTA,txPasmPinMask
waitcnt txPasmTimeout,TxPasmBitTime
djnz txPasmBitCnt,#TxPasmSendBit
These are is a bit-banged serial input and output routines ( idles low, start bit high ) ... How do I determine what the K's should be to get most accurate time from when INA pin goes high to when INA is next sampled and likewise to get the first bit length right in the tramsit.
This is the application for which I most often use Gear.
Looking at the code though, you've got no instructions that would require anything other than 4 clock cycles. So just count up the number of instructions and multiply by 4. (Initial guess would be 28 for the first k, and about 8 for the second k).
Other than that, I've never heard of PSM, but I did notice that you've got a bit-and-a-half delay on the receiver - which is a good thing to get you to the middle of the bit period.
"Multiply by 4" ... D'oh ! Not multiply by 1, it's CNT++ every cycle, not per instruction.
