info on PVI module for EInk display
Ehi..I have gotten a EInk display from Prime View. It comes with e modul that drives the display.
Has anyone of you ever run across one of this display?
I am attempting to write the driver but·even though the module reply to my queries, there is nothing to do when it comes to display images.
Any info on existing drivers???
Nicola
Nicola
The problem I am having is on the transmission of data. Basically there are commands with parameters and commands without.
When I send a command without params, I receive a reply so it works.
when I senda command with params, the bus rises and error. I guess I am doing it the wrong way but the small doc I have is not telling much.
Documet states that H_CD has to be high when sending command and low when sending data.
Since I have implemented the function to send a command, I reuse the same to send the parameters right after the command has been acknowledged. Unfortunately I cannot publish it since PVI sent it to me without authorization to publish it but i guess nothing wrong to send it by email [noparse]:)[/noparse] .. right???? [noparse]:)[/noparse] [noparse]:)[/noparse]
I think that by reusing the same WRITE function (which re-init the values of all lines for writing) I reset the previous command. It would explain why commands without params work.
How does usually work in other devices?
I am quite new to this area......
Thx!!!
