Need help with stepper motor program
I wrote a rather lengthy program to control my senior design project, but the stepper motor part of it is causing a problem.· I need the stepper motor to rotate 132 times, that is 26,400 steps.· When the program gets to that part of the program the stepper motor rotates maye 10-20 times and then the whole program restarts.· This is the part of the program giving problems.
Rotate_Vert:
DEBUG "Rotating to Vertical: "
· Steps=26400
· DEBUG DEC Steps
· DEBUG " "
· OUTA=$1
· PAUSE 007
· DO
··· OUTA=$2
··· PAUSE 007
··· Steps=Steps-1
··· IF (Steps=0) THEN EXIT
··· DEBUG DEC Steps
··· DEBUG " "
··· OUTA=$4
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
··· OUTA=$8
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
··· OUTA=$1
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
· LOOP
· PAUSE 1000
· OUTA=$0
· Status=1····· 'Position is remembered
DEBUG "Now in Vertical Position - "
Does anyone know why this would happen?· I have rewritten the program a few different ways and the result is always the same.
Post Edited (Keith Vand) : 4/5/2008 7:23:18 PM GMT
Rotate_Vert:
· Steps=26400
· DEBUG DEC Steps
· DEBUG " "
· OUTA=$1
· PAUSE 007
· DO
··· OUTA=$2
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
··· OUTA=$4
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
··· OUTA=$8
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
··· OUTA=$1
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
· LOOP
· PAUSE 1000
· OUTA=$0
The problem may be in how you have declared the variables.
phil
' {$STAMP BS2}
' {$PBASIC 2.5}
DIR0=1
DIR1=1
DIR2=1
DIR3=1
DIR15=1
Time VAR Nib
Cycles VAR Nib
Status VAR Bit
Steps VAR Word
Cycles=0
Status=0
FOR Cycles = 1 TO 15
· IF (Status=0) THEN GOSUB Move
· IF (Status=0) THEN GOSUB Rotate_Vert
· IF (Status=1) THEN GOSUB Dive
· IF (Status=1) THEN GOSUB Rotate_Hor
· DEBUG "End of Cycle "
· DEBUG DEC Cycles
· DEBUG " - "
NEXT
Hold:
GOTO Hold
Move:
DEBUG "Move Sequence: "
OUT15=1
Time=15
DO WHILE (IN13=0)
· DEBUG DEC Time
· DEBUG " "
· PAUSE 1000
· Time=Time-1
· IF (Time=0) THEN EXIT
LOOP
OUT15=0
DEBUG "End of Move Sequence - "
RETURN
Rotate_Vert:
· Steps=264000
· DEBUG DEC Steps
· DEBUG " "
· OUTA=$1
· PAUSE 007
· DO
··· OUTA=$2
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
··· OUTA=$4
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
··· OUTA=$8
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
··· OUTA=$1
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
· LOOP
· PAUSE 1000
· OUTA=$0
RETURN
Dive:
DEBUG "Dive Sequence: "
OUT15=1
DO WHILE (IN14=0)
· PAUSE 1000
· DEBUG "Diving... "
LOOP
OUT15=0
DEBUG "End of Dive Sequence - "
RETURN
Rotate_Hor:
DEBUG" Rotating to Horizontal: "
· Steps=264000
· DEBUG DEC Steps
· DEBUG " "
· OUTA=$1
· PAUSE 007
· DO
··· OUTA=$8
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
··· OUTA=$4
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
··· OUTA=$2
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
··· OUTA=$1
··· PAUSE 007
··· Steps=Steps-1
··· DEBUG DEC Steps
··· DEBUG " "
· LOOP
· PAUSE 1000
· OUTA=$0
· Status=0······· 'Position is remembered
DEBUG "Now in Horizontal Position - "
RETURN
driving the motor are needed to limit the current from the Stamp.
From the Basic Stamp FAQ:
On the BASIC Stamp I and BASIC Stamp II, each I/O pin is capable of
sourcing 20 mA and sinking 25 mA. The total across all I/O pins should
not exceed 40 mA source or 50 mA sink at any given time, however.
One exception to this rule exists with the BS2-IC. If the BS2-IC is powered
by an external 5-volt regulator capable of delivering at least 100 mA, the
total across each group of 8 I/O pins (0 - 7 and 8 - 15) can reach 40 mA source
or 50 mA sink providing a total of 80 mA source or 100 mA sink overall
In addition, it may be a power supply issue.
Try running the Stamp from a separate source.
phil
Post Edited (phil kenny) : 4/5/2008 10:23:36 PM GMT
