Connect Two Professional Development Boards Using One Battery Source?
Bill Chennault
All--
I am not satisfied with the big Jameco breadboard on my robot, Ugly Buster. It is very large and that is nice, but it is not as mechanically sound as a PDB. I have two PDBs sitting in drawer. I want to run both off a single 12 volt battery source (two 12 amp hour batteries in parallel for a total of 24 amp hours). IF I can do this, THEN I can eliminate the dual 7.2 volt, 8400 mah battery packs that operate my logic and will be able to run EVERYTHING off the 12 volt batteries.
What I would LIKE to do is build a simple "Y" connector that allowed me to plug 12 vdc into both PDBs. There would be logical connections between the PDBs, breadboard to breadboard. Can I do this or am I missing something? Remember that I am a newbie.
Thanks!
--Bill
You are what you write.
Thanks!
--Bill
See page 9 of the LM317 datasheet (www.national.com/ds/LM/LM117.pdf) for a good sample circuit. You'd want a 0.1uF input capacitor mounted close to the regulator and at least a 100uF 15V output capacitor.
As always, thank you for the answer. I would have THOUGHT about the regulator because I have learned that the energy must go SOMEWHERE. However, I doubtless would not have implemented one. You have made it too easy to skip!
Thanks!
--Bill
