Program Propeller via BlueSMiRF?
Has anyone been able to replace the serial cable from the PC to Propeller for the purpose of programming (uploading) to the Prop? I have a Sparkfun (Roving Networks) BleuSMiRF module. I can connect to it and issue configuration commands, but would like to use it in place of the serial cable. When I try this, the Prop Tool just hangs while identifying the hardware. Any suggestions?
Win
Win
Paul Baker
Paul Baker
Win
Please post any success you have with this.
Win
I may be wrong because it's been awhile since I played with my eb500, but I think it wasn't enabled on start-up.
It had to be put in command mode, turned on, and then put back in data mode before the RTS-CTS pins would work.
maybe yours needs those settings saved to it's default settings before it will handle flow control.
Maybe some one else can confirm this.
Paul Baker
