Using Pull-up resistors with the prop ?
Hello All,
I will be monitoring three inputs on my Prop Proto board on pins 4,5 & 6.
These pins will be attached to 3 limit switch's that are normally open. Should I use pull-up resistors from 6.6K - 10K, I have been looking but do not see anywhere that the Prop has internal resistors for this purpose, Is this correct?
JMLStamp2p
JMLStamp2p
What size pull-up would you normally use yourself for this ?
