Have I lost it???
I'm trying to get my BS1 started. I have the old printer port cable
and I plugged in everything and the Win software doesn't recognized
the port or can't find it. There's nothing there to select a port.
And why does it keep saying serial port when I have a parallel port?
I don't have the smaller 9-pin serial port... is that a problem?
Thanks.
The Windows Stamp Editor only uses a serial port for programming and you have to use the adapter.· If you want to use the parallel port programming, you have to be running DOS or Windows 95 / 98 and using the DOS version of the Stamp Editor.
Post Edited (Mike Green) : 4/4/2008 2:02:07 AM GMT
not with Parallax.
Now I'm going to have to buy and wait for delivery. Wait a minute - my PC doesn't have
a serial port so I'm going to have to get the USB adapter as well. I have Vista & XP - only
because I had to downgrade to XP to get stuff to work.
Thanks.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
but it didn't even include a serial port.
I think I might have a serial 2 parallel cord. Would that work anyone???
I'd probably still need an older operating system wouldn't I?
Thanks anyway.
