The great mystery volt caper
I'm trying to hook up a a/c to DC adapter to my BS1.
It is a 120v to 9V adapter and I want to hook it up using the
9v battery hookup and not the Vin.
But on testing it with a volt meter - it registers a constant
fluctuation of volts up to 16V.
I tested 3 adapters and all gave different readings - far higher
than the rated volts that is 9 - which I think could be dangerous
for the 9V port and the BS itself.
The reason I'm doing this is that I need the BS to be constantly
powered for my test. Using a 9V (8.77v) battery can fail at any time and
destroy the results of my test.
Thanks.
Thanks.
- Stephen
Thanks.
http://www.jameco.com/Jameco/catalogs/c281/P159.pdf
The ones that are 9 volt work very well for this type of application. The plug is·exactly what you need for Parallax dev boards (2.1mm center positive).
- Rick
I guess you learn something new everyday.
