Proto Board new clock — Parallax Forums
PropabilityPropability Posts: 142
edited 2008-04-03 23:54 in Propeller 1
Thanks to some recent posts I decided to see if I could get video back working on a protoboard that I snuffed the PLL on. The Prop could still use the crystal but no PLL settings. Ordered a 80Mhz crystal oscillator (all they had were smd but that worked out ok) and removed the "+ pll16X"· and changed the xinfreq statement to 80_000_000 in the graphics demo and it works! Thanks again for giving the idea to do this.
Pete
  • RaymanRayman Posts: 15,379
    edited 2008-04-03 20:04
    Nice. Can you give a link to the part you used? This sounds easier than replacing the chip...
  • groggorygroggory Posts: 205
    edited 2008-04-03 23:41
    What is the advantage to using an 80 MHz clock over a 5 MHz clock w/ 16xPLL ?
  • CJCJ Posts: 470
    the advantage is the 80 will work when the PLL is fried.
    Parallax Forums - If you're ready to learn, we're ready to help.
