Boe-Bot help!?
Hey guys,
I just don't get why this makes the Boe-Bot go backwards,
PULSOUT 13, 650
PULSOUT 12, 850
And this·makes it do a left turn,
PULSOUT 13, 650
PULSOUT 12, 650
And this makes·it take a·right turn,
PULSOUT 13, 850
PULSOUT 12, 850
Cause I mean if you send the same amount of pulses to each motor wouldn't it go forward?
Sorry I'm new to the Boe-Bot so please help!
Dan Taylor
PULSOUT 13, 650
PULSOUT 12, 850
PULSOUT 13, 650
PULSOUT 12, 650
PULSOUT 13, 850
PULSOUT 12, 850
Dan Taylor
Dan Taylor
PULSOUT 12, 650
The above would be forward. Remember one motor is "mirror image" of the other -- it's mounted "flipped" on the Boe-bot chassis. So you have to run one motor "forward" and one "backward" to go forward because the "backward" motor *is* backward.
If it's too much, you could put your "motor out" commands into a subroutine that flips the value for you, i.e.
Dan Taylor
