Serout
Good Morning Everyone,
·· I am trying to find out how long of a transmission line I can have using the SEROUT command.· In other words what is the longest distance I can have between a bs2p40 and a pololu micro servo controller.· Also while reading up on SEROUT I noticed the tpin can be driven or not.· Is this what you would use to increase the distance between devices.· One more, what exactly is a line driver.· Thanks a bunch in advance.
As always you are a source of knowledge.· What about the driven or non driven I/O pin?· Whats that all about?
I haven't tested anything, but I have a feeling I am going to need a line driver for my app.· I am going to be sending serial data from a bs2p40 to the servo controller over a distance of 60'.· I think it would probably be best for me to use the RS-232 set up but do not know how to select a driver.· Could you please help me with this issue.· Thank you.· Attached is the documentation for the servo controller, I believe I will not need a reciever because the controller accepts RS-232 signals.· Please correct me if I am wrong.· Thank you again.
