Having troubles with KS0108b based lcd from sparkfun
I tried the ks0108b driver from the object exchange on a lcd i bought from spark fun but here is how far i have got
changing CS1 and CS2 around doesnt change anything...
is it possible that a cold solder joint would do this....
also, is it safe to say that the lcd itself (the screen and the ICs) are in good condition
Post Edited (Lethal Python) : 4/3/2008 4:12:06 PM GMT
IOpins = %00000000_00000000_00111111_11111111 'set output pins DI = 12 RW = 11 Ena = 13 DB0pin = 0 'For reversed pins set to db7 and make active first two lines of #writebyte db0_db7 = %11111111<<DB0pin CS1 = 9 CS2 = 8 RST = 10
here is a video of what it does now
www.youtube.com/watch?v=5vJMAG_ut3Q
This is tipically an inversion between CS1 and CS2 !
BR
