farther IR detection?
how can I accomplish farther LED detection that with what comes with the bs2 kit? I see that radio shack sells some high power IR LED's..could I use those with the bs2 or not compatible? I am trying to reach distances of 36 inches. meaning with the simple program on the bs2 I could hold my hand 36'' from the IR LED and It would detect it and do whatever the program called for. So how can I achieve this distance of detection?
Actually I think Im going to add the whiskers to my tank and let it roam, just need to figure out where.
As long as you don't leave "on" the IR LED (in other words, use it with "FREQOUT IR_Pin, 38500"), you might be able to extend the distance a little -- but 3 feet is pretty long. The "Ping" module will work out to 10 feet, that might be a better choice.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=170180171809&ssPageName=STRK:MEWA:IT&ih=007
They claim a range up to 1500cm (6 feet)
I bought one. I havn't had a chance to test it yet. I can let you know how it works.
