PIR motion sensor questions
Hi guys I'm a little knew to robotics and electronics in general. So forgive if I come across as an idiot.
I'm trying to build a simulation claymore that is motion activated. I'm using the·PIR module seen here. http://www.parallax.com/Store/Sensors/ObjectDetection/tabid/176/CategoryID/51/List/0/Level/a/ProductID/83/Default.aspx?SortField=ProductName%2cProductName
I just have a few question as far as the wiring and operation of the sensor
1. It says that the maximum voltage is 5V, now would it damage it at all if I ran at 6v instead since that's the power supply I'm using.
2. Do I have to use a micro controller with the sensor in order to activate a simple circuit, or could I wire the output pin directly into the circuit
3. How high would the output voltage be if 5v or 6v was used as a power source.
Thanks in advance for any help.
2) Read the documentation. The output can be used to trigger an external transistor switch. I wouldn't try to drive anything else directly.
3) For a 5V supply, the output is likely to get up to about 4.4 to 4.6V. Anything over about 1.2V is normally considered to be a logic true value for some circuits. Other circuits assume that anything over 1/2 the supply voltage is a logic true output.
·My power supply is 4 nimh AAAs (4.8v total).
Check the power supply voltage. You really need 5V. If the batteries are a little low, the sensor may not work.
My question,
How many milliamps can the output safely supply when the output is high?
www.fd.com.my
www.mercedes.com.my
