SX-Key USB
How do I need to use the SX-Key USB with the software since it only allows setting up via a comport? I read through the manual but nothing is listed for the usb key. I also checked the website for it and checked the pdf and it is the same. I actually had this as a spare and sent it to a friend.
Kevin
Kevin
Are you talking about the SX-Blitz USB ? I don't think Parallax is selling the USB SX-Key yet.
Bean.
www.iElectronicDesigns.com
Robert
It probably is if that is the only one for usb. So the difference is just not going to be able to do in circuit debbuging correct?
Robert,
I just thought it may need a driver from FTDI for virtual comport!
Thanks Guys,
Kevin
Yes the Blitz cannot debug and also doesn't have the clock generator either.
The USB-Blitz uses the FTDI chip so it appears to the system as a COM port.
Bean.
