Quick questions on navigation(solved)
Just a few quick questions.
1. Can GPS coordinates be inputed and have a GPS unit in conjunction with a BASIC Stamp lead the robot to it?
2. Does the PING sensor tell which direction the signal bounced back from?
Thanks!
Post Edited (curious_roboticist) : 4/2/2008 9:52:24 PM GMT
Thanks!
2) No. The signal can return via a wall or other surface and the PING can't tell the difference
If all three see the same distance then it is in front of you. By compairing three three sensors I wonder if you could tell left - front - right ?
Edited to add: I my drawing got smushed and I don't know how to fix it.
Searider
Rather than spending money on three PING)) Sensors, why not use just one PING )) Sensor and rotate it with an R/C servo? That will provide about the same output much more economically.
Parallax Part Number 570-28015 contains everything you need to provide that kind of rotating action when the sensor is mounted on a robotic platform.
Bruce Bates
Involvement and committment can be best understood by looking at a plate of ham and eggs. The chicken was involved, but the pig was committed. ANON
I was confused by your answer. I was asking if the Stamp can use the GPS unit to plot a course to coordinates that I enter in?
Searider
