wh doesn't the order matter, LED and resistor.
I noticed I can take the 5 volts through a resistor to the LED then to ground OR take the 5 volts to the LED then to the resistor and then to ground. Why does it work either way? doesn't that put 5 volts on the LED first and damage it? I would imagine having the resistor after the LED and before ground would be useless. Im so lost.
Actually I think Im going to add the whiskers to my tank and let it roam, just need to figure out where.
Now, if you took the resistor OUT of the branch, then yes, you'd burn up the LED, so don't do that.
1. A resistor is a linear device. This means, the current/voltage curve of the device is a straight line. The slope of this line is the resistance of the resistor.
2. The LED is a non-linear device. This means, the current/voltage curve of the device is not a "linear" relation, like the resistor. In fact, it looks sort of linear, until you reach 1.4 volts, at which time the voltage stops rising, while the current continues to rise. What this means is, if you TRY to put 5 volts across a single LED, the LED voltage will rise to 1.4 volts, then the current will try to go to infinity (or more than 25 mA, which is the burn-out current of the LED) and the LED will then act like a fuse, and burn out.
So, we MUST put some linear element in that branch to limit the current through the LED.
So, ok, we have a branch with an LED, and a resistor in it. When the voltage goes on, the LED will drop its 1.4 volts. So the resistor must 'drop' the rest of the voltage, at a current low enough not to damage the LED.
So V = IR, means I = V/R. V == 5 volts - 1.4 volts == 3.6 volts that the resistor must 'drop'. If we pick a 470 ohm resistor, 3.6 volts / 470 ohms == .00766 Amps, or 7.66 milliamps through the branch (through the LED, AND through the resistor) -- which is good.
If we pick a 220 ohm resistor, we get 3.6 volts / 220 ohms == 16 milliamps. Which is okay, but probably 9 milliamps more than we really need to light the LED.
If we pick a 120 ohm resistor, we get 3.6 volts / 120 == 30 mA, which absolutely WILL burn out the LED.
Okay, if you make the voltage BIGGER, then still 1.4 volts will be dropped across the LED, so V_Bigger - 1.4 volts / Resistor == the current. Pick a Resistor value to keep "the current" result between 7 and 16 mA, and your LED should be protected.
And this analysis works, no matter what order the LED and Resistor are placed into the circuit, as long as they're in series with each other.
to negative pole. In a typical conductor the negative charges are free electrons, positive charges are the positive "holes" left behind by the
displaced electrons. Both flows occur at the same time. Thus the conception of current flowing "first" through the resistor "and then" through the LED -- or the other way -- is just false.
It would be just as hard·to move the car forward·as it would be to move the car in reverse.
The resistance caused by the sand dragging against the bottom of the car would prevent the cars energy from moving the car quickly.
How can there be·nothing? Nothing is something!
