LB SMT (finally good news)
LB·SMT was notified today, that our new Pick & Place was ready to go on the truck to be delivered.
We are not sure how long it will take to get to us....but we will need about three days to get everything arranged and setup to our liking before processing boards.
We hope at least a few Parallax users will consider the service.
We will only post once more on the Parallax forums about the service. It is not our intentions to spam the forum, more to just let everyone know the service is out there.
We are planning to have a Grand Opening special when the time is right.
James L
James L
Partner/Designer
Lil Brother LLC (SMT Assembly Services)
James L
James L
Partner/Designer
Max Wooden
Reedley, California
It has been a very large learning experience. We started out with what we thought was a simple idea......and how wrong we were.
It has not been a disaster, but there have been all kinds of hurdles that we never expected. That is the difference in, thinking you know......and knowing.
We do not have all the bases covered as of yet. But they will be covered as soon as possible.
Our biggest trouble we have at the moment, is the inability to do boards from services like ExpressPCB (if the board has a large amount of pads). We have no way to convert the known data into a stencil for solder pasting. We can do small boards, but big boards just take too long for pasting solder dot by dot.· The only way we know of ; is to get the gerber from the service, or scan the board with one of the new reverse engineering systems. The scanning systems cost around $21k, so it may be a while before we can afford to purchase one.
We are also going to do some advertising for some select companies. For now the advertising is free. (Yes, Parallax is one of them....we figured we owed them something for all the spam.......
I hope everyone will at least consider our service. We are aimed at the private hobby business types. We also have some larger business types that have contacted us as well. We have had great feedback so far about the service.·The next step is to insure our quality is in-line with the competitors. We have worked hard to choose carefully for quality. We didn't buy the most expensive machinery, but we did buy machinery we can maintain a high level of quality with.
I hope to see a lot of the familiar faces from Parallax placing job orders......
James L
James L
Partner/Designer
So you are going to use a solder screen ? I had assumed you would drop solder dots for everything.
Bean.
www.iElectronicDesigns.com
We are only going to drop dot's for small runs with few pads. We really want to get away from this totally.......but time will tell.
We will be using stencils probably on 98% of everything we run. (We are not going to charge for the stencil, unless the customer wants to recieve it).
Mylar stencils of course (for most things)......if the run is a month repeat....we will probably order a metal stencil.
James L
James L
Partner/Designer
