No response from EB500
I'm new to the robotics scene and have gone through the What's a Microcontroller and Boe-Bot books and have a completed boe-bot. I purchased an eb500 bluetooth AppMod and have been unsuccessful at getting any responses from it. I've run out of ideas as to how to get it to respond. I can't even get an ACK or NAK from it. I've tried using the StampEditor and uploading the getaddress.bs2 sample program with no luck. Have also tried making requests from HyperTerminal and have had no luck. I'm using a BT-201 bluetooth dongle on windows vista. When I used the get address program and upaded it to the stamp the program gets to the point of issueing the get address command and gets no reponse. The program doesn't go beyond that point. If anyone could offer any suggestions I would greatly appreciate it. FYI, the status light on the bluetooth AppMod is lit when the devices are paired and connected on COM 7. Thanks.
···· http://forums.parallax.com/showthread.php?p=716758
I posted a PDF file there that should help you with your problem.
Go there and down load the PDF and have a look.
Post Edited (SamMishal) : 3/31/2008 9:24:02 AM GMT
