AVRCam capabilities — Parallax Forums
AVRCam capabilities
superherosuperhero Posts: 10
edited 2008-03-30 17:01 in Robotics
Hello there
i wanna ask about level of processing for the AVRCam and CMUCam(Do cams do any kind of processing on the taken images)
and What is the type of the data that AVR and CMU sends (e.g. coordination, position, direction)?
waiting for the answer
have a nice time
    edited 2008-03-30 14:27
    There's lots of documentation on both devices that goes into detail on what you can get from the cam. You should download and read the manuals first, then ask about anything you don't understand.
    Here's the AVRcam page: www.jrobot.net/Projects/AVRcam.html
    Here's the CMUcam start page: www.cs.cmu.edu/~cmucam/
    Post Edited (Mike Green) : 3/30/2008 2:33:20 PM GMT
  • superherosuperhero Posts: 10
    edited 2008-03-30 14:30
    thx i read that manual but it doesnt give me enough info. that i need
    can you help me to find other resources
    My Regards
    edited 2008-03-30 14:35
    The manuals are pretty explicit about what the cameras provide. They're intended primarily for educational purposes, so there's a lot of information that comes with them. What other information do you need and why?
    edited 2008-03-30 14:41
    oh
    i need it for using it with a robot that based on a handy board so i need to know the whole capabilities
    of the image processing level that it can provide to me,and What is the type of the data that AVR sends (e.g. coordination, position, direction)?
    and thx for your help
    edited 2008-03-30 15:04
    Again, read the manual. The AVRcam documentation lists all the commands that the cam will respond to and shows the exact response from the cam for each command. The CMUcam comes in 3 different versions and the manuals for each have even more detail on what you send to the cam and what is sent back.
    The AVRcam essentially has two capabilities. 1) It can provide a "dump" of the screen contents, essentially a "snapshot". 2) It can track up to 8 "blobs", areas of specific color that you specify and continually report the coordinates of the centroid of the blobs.
    The original CMUcam was similar. The latest version has a interpreter for the programming language LUA and can control several servo motors based on the tracking information. Read the CMUcam3 manual for the details.
    Post Edited (Mike Green) : 3/30/2008 3:14:00 PM GMT
    thx alot for your help
    and if i have any thing i will ask for a help
