You would be able to modify it to run it on a Protoboard, but not with the keyboard. There isn't enough memory to add a keyboard driver. What you would need to do is wire up your joypad interface and go that route.
What should the startup screen look like? I just get two lines on the screen and a very stretched light box. Also, what should the lights on the keyboard do? They just flash once and then turn off.
When the game starts up, it zooms the title X-Racer in and out and when you hit start, it starts the game. But if you hold down start, the game will freeze until start is released. So I am thinking that the start button in memory is set as pushed instead of not pushed in. If you still have the section of code that is trying to read the joystick ports, I would comment that out so it isn't putting in false data to interfere.
edit: just comment after from the line after
racer_bg000
to the end of the file [noparse]:)[/noparse] add in keyboard
· key.start(26,27) ' whatever pins the keyboard are on
around the tv.start and snd.start,
then·add
· if(key.keystate(KB_RIGHT_ARROW))
·· nes_bits &=!NES0_RIGHT
· if(key.keystate(KB_LEFT_ARROW))
·· nes_bits &=!NES0_LEFT
· if(key.keystate(KB_UP_ARROW))
·· nes_bits &=!NES0_A
· if(key.keystate(KB_DOWN_ARROW))
·· nes_bits &=!NES0_B
· if(key.keystate(KB_ENTER))
·· nes_bits &=!NES0_START
· if(key.keystate(KB_SPACE))
·· nes_bits &=!NES0_SELECT
before
· nes_bits := (!nes_bits & $FFFF)
oh, and add
· ' control keys
· KB_LEFT_ARROW· = $C0
· KB_RIGHT_ARROW = $C1
· KB_UP_ARROW··· = $C2
· KB_DOWN_ARROW· = $C3
· KB_ESC········ = $CB
· KB_SPACE······ = $20
· KB_ENTER······ = $0D
into the CON section
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
Post Edited (Baggers) : 3/30/2008 11:06:14 PM GMT
