LCD AppMod Help
· Ive posted a form already about this before, but im still puzzled. I have an Lcd AppMod, ive downloaded the demo for it and I dont konw what to do, The soure code is huge, I dont know how to write anything for . For example to make a word scroll across the screen, NOT A CLUE!!! Im disapointed, because now I fell like I wasted $25.00 on this thing, but I know I didnt. Im planning on makeing it display if My BOE-Bot has incountered an object, im using the infrared LEDs. When the left IR LED has incountered an obstical it wil display "IR LEFT" etc. I know the souce foe the boe-bot, but not the LCD AppMod. Please contact me as soon as you can!
THANKS·
·Joshua Peters
THANKS·
·Joshua Peters
Is this the Demo Code that you used that is below
··Thanks for any·
Sam
I would ask questions about anyone of these lines that you do not understand
If i had one to play with i would give it a try my self but I do not have one
But what i have here.........>>>>>>
I·would try· what is here·and see if this·will·work just the part·that control the ·scroll part of the program
·If this scrolls the message·across the screen then you know that this need
·Then·you need to understand· what line··dose what
Then you will know how to do what you want to do
Now·I may have left·something out that is need but I·do not see it right now and if so then may be some one on the Forum may be able you more
You will need all of the I/O Definitions,Constants and Variables
[noparse][[/noparse] I/O Definitions ]
[noparse][[/noparse] Constants ]
[noparse][[/noparse] Variables ]
[noparse][[/noparse] EEPROM Data ]
Msg1 DATA "PARALLAX", 0
Msg2 DATA " BASIC STAMP ", 3, " ", 0
Msg3 DATA "Type =", 0
Msg4 DATA "Buttons:", 0
[noparse][[/noparse] Program Code ]
' Scroll a message across LCD line
' -- set starting position in 'crsrPos'
' -- point to 0-terminated string (first location in 'addr')
' -- strings should be padded with eight spaces on each end
Main:
char = LcdCls········································ ' clear the LCD
GOSUB LCD_Command
PAUSE 500
Write_Parallax:
addr = Msg1·········································· ' point to message
GOSUB LCD_Put_String································· ' write it
Scroll_Message:
crsrPos = LcdLine2··································· ' scroll on line 2
addr = Msg2·········································· ' point to msg
GOSUB LCD_Scroll_String······························ ' scroll it
'________________________________________________________________
' Write character to current cursor position
' -- but byte to write in 'char'
LCD_Write_Char: ' write character to LCD
#IF _LcdReady #THEN
LCDOUT E, 0, [noparse][[/noparse]char]
#ELSE
LcdBusOut = char.HIGHNIB························· ' output high nibble
PULSOUT E, 3····································· ' strobe the Enable line
LcdBusOut = char.LOWNIB·························· ' output low nibble
PULSOUT E, 3
HIGH RS·········································· ' return to character mode
#ENDIF
RETURN
·'______________________________________________________________
Show_Stamp_Type:
GOSUB LCD_Command
PAUSE 100
addr = Msg3·········································· ' display "Type ="
char = LcdLine2 + 3·································· ' move cursor to 2nd line
GOSUB LCD_Command
#SELECT $STAMP······································· ' check type at compile
#CASE BS2
addr = StampId0
#CASE BS2E
addr = StampId1
#CASE BS2SX
addr = StampId2
#CASE BS2P
addr = StampId3
#CASE BS2PE
addr = StampId4
#ENDSELECT
[noparse][[/noparse] Subroutines ]
' Writes stored (in DATA statement) zero-terminated string to LCD
' -- position LCD cursor
LCD_Put_String:
DO
READ addr, char
IF (char = 0) THEN EXIT
GOSUB LCD_Write_Char
addr = addr + 1
LOOP
RETURN
LCD_Scroll_String:
DO
char = crsrPos···································· ' move to start of window
GOSUB LCD_Command
FOR idx = 0 TO 7·································· ' write chars in window
READ (addr + idx), char
IF (char = 0) THEN EXIT··························· ' stop if end of string
NEXT
addr = addr + 1 ' scroll
PAUSE LcdScrollTm
LOOP
RETURN
' Send command to LCD
' -- put command byte in 'char'
LCD_Command:······································ ' write command to LCD
#IF _LcdReady #THEN
LCDCMD E, char
RETURN
#ELSE
LOW RS
GOTO LCD_Write_Char
#ENDIF
' Reads byte from LCD
' -- put byte address in 'addr'
' -- returns byte read in 'char'
LCD_Read_Char:·································· ' read character from LCD
#IF _LcdReady #THEN
LCDIN E, addr, [noparse][[/noparse]char]
#ELSE
char = addr ' move cursor
GOSUB LCD_Command
HIGH RS········································· ' data command
HIGH RW········································· ' read
LcdDirs = %0000································· ' make LCD bus inputs
HIGH E
char.HIGHNIB = LcdBusIn························· ' get high nibble
LOW E
HIGH E
char.LOWNIB = LcdBusIn·························· ' get low nibble
LOW E
LcdDirs = %1111································· ' return data lines to outputs
LOW RW
#ENDIF
RETURN
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 3/31/2008 4:07:28 PM GMT
