Little Step-U Motor Controller for Propeller
·Hello,
··········· I am working on a project which connects a Propeller to a ‘Little Step-U Motor Controller’ (Parallax Item code 27938) and ‘4-Phase / 12 Volt Unipolar Stepper Motor’· (Parallax Item code 27964).· I have found several *.spin files for stepper motors, however I have not found anything for the ‘Little Step-U’ controller in the form of an object, or demo.· Has anyone tried this?· There is BS2 code on the Parallax website, however I am trying to make this work on a Propeller.· Thanks in advance.
Cheers,
Michael
Cheers,
Michael
The same commands are set to the motor controller. Instead of using SEROUT statements, the Propeller would use calls to serial I/O routines that either transmit a string or convert a number to a sequence of digits and transmit it.
Post Edited (Mike Green) : 3/29/2008 10:24:16 PM GMT
Thanks for the direction. I have tried both the Simple_Serial as well as the BS2_functions. I have pasted my code below. This project is wired up the way the Little Step-U manual suggests.
... also from the manual...
>Software commands
>Communication with the Little Step-U is by a TTL level serial interface at 2400bps. All
>commands must begin with a "{" character and end with a "}" Characters outside of the braces
>(including carriage return and line feeds) are ignored.
I think there is a problem with how I deal with the serial message is to be sent. In the following code I used ‘{D1000}’, which is supposed to rotate the motor 1000 steps. I am not sure if I should treat this is a string or what? What would the correct syntax look like? The last five lines are different versions that I have tried.
Cheers,
Michael
' P0 -> serial in
' P2 -> busy
' P3 -> IP2
' P5 -> Vcc (Vss with res and cap)
CON
_CLKMODE = XTAL1 + PLL16X
_XINFREQ = 5_000_000
steps_per_rev = 48 ' # of steps per rev
time_step = 5 ' time step
speed = 200 ' rotation speed
VAR
Long stack1[noparse][[/noparse]50] ' Stack for 2nd BS2 Cog
OBJ
serial : "Simple_Serial"
BS2 : "BS2_Functions_1_3_5" ' Create BS2 Object
PUB main
serial.start(-1 , 0, 2_400) 'start(rxPin, txPin, baud)
BS2.start (-1, 0) '(rx, tx)
serial.tx(string("{D1000}")) '(txByte)
BS2.Debug_Str(string("{D1000}")) '(stringPtr)
BS2.SEROUT_STR(0,string("{D1000}"), 2400, 1, 8) '(Pin, stringptr, Baud, Mode, bits)
BS2.SEROUT_DEC(0,string("{D1000}"), 2400, 1, 8) '(Pin, Value, Baud, Mode, Bits)
BS2.SEROUT_CHAR(0,string("{D1000}"), 2400, 1, 8) '(Pin, char, Baud, Mode, Bits)
2) string("{D1000}") supplies the address of the string constant. This is exactly what is needed by either BS2.SEROUT_STR or serial.str
3) If you want to provide a variable numeric value, you can combine the .str calls with a .dec call like:
serial.str(string("{D"))
serial.dec(1000)
serial.str(string("}"))
4) The same sort of thing works with the BS2 calls
