CRT O-Scope
Hi Guys,
Just wanted to know..is it safe to test the Basic Stamp outputs with a CRT Oscilloscope.
R
R
The danger can come with multiple input/trace scopes where a short can inadvertantly be put on a circuit when using more than one probe at a time.
A lot of modern scopes have isolated inputs to stop this happening although the O'scope spec doesnt specify isolated inputs so if you have a dual trace version with two inputs then be careful how you attach the probes in order to avoid shorts as it may not have isolated ground connections this is especially important if your circuits involve different voltages, for instance your basic stamp circuit is used to control a mains powered part of your circuit.
Post Edited (skylight) : 3/29/2008 9:44:44 AM GMT
