Measuring speed with the Parallax Ultrasonic Rangefinder
I have heard people talk before about measuring the speed of a moving object with the Ping))) sensor. Is this possible? Any ideas to where I should start?
Giggly Googley!
Giggly Googley!
BTW, you should be able to delete your other thread before anyone else posts to it. Just click the X in the upper righthand corner.
So, by slow enough, how slow are we talking here? And by Doppler, what exactly do you mean?
Giggly Googley!
Giggly Googley!
Assuming the object whose velocity you want to measure is coming towards you, take two distance readings. x0 is is the first one, x1 is the second one, so x0 - x1 is the distance the object moved. If the intervening time between the two readings is t, the average velocity of the object during that interval is given by the formula.
With the right equipment, instantaneous velocity measurements could be obtained by determining the Doppler (wavelength) shift of the reflected ultrasonic wave pulse (the train whistle effect). This is the method used by police radars, except using radio waves in the GHz region instead of sound waves in the KHz range.
Giggly Googley!
