How to use AA size battery to drive Solenoid
I use 4 AA size battery to drive a solenoid of 4 Ohm. When batteries are new, everything is OK. But when voltage goes down to 5V, there is a suddent dip in
battery voltage to below 2V. I use a MCU to turn on a switch for 500ms, which drain current of 850mA. How can I drive the solenoid in this condition without causing the voltage to drop to 2V?
http://forums.parallax.com/forums/emoticons/jumpin.gif
jumpin
jumpin
When batteries discharge, their internal resistance increases. That's why you see the voltage plummet under load. Once they reach this point, there is little you can do to extract more useful energy from them.
Is there any reason that you have to run·this drive a solenoid of 4 Ohm
Because it may better to run it off of a tranformer....>>>this is just an
··Thanks for any·
Sam
