current sourced/sinked when connecting two BS2's
If I connect a pin of one BS2 ,·set to·output HIGH,·to a pin on a·second BS2 set to input, what will be the current sourced/sinked (common ground, of course)? This is assuming there are no resistors installed on the pins (not a·Homework Board).
Richard·
Richard·
The problem is as was stated above -- if the 'input' BS2 accidentally sets that pin to an 'output', and 'outputs' a LOW, you'll have a dead-short (very low resistance connection) between Vdd and Vss, which will burn out the transistors behind one or both pins. A 220 ohm resistor between the two I/O pins will prevent damage should that happen.
