Accelerometer and led
I'm using the code from the online books on the accelerometer and i decided to try to make a led light up when the x-tilt reached 10 degrees.
Of course it is not working and i would like some help please.
Heres the code.
it just lights up as soon as i start the program
Post Edited (Ctrl.Alt.De1337ed) : 3/28/2008 4:37:06 AM GMT
Heres the code.
' {$STAMP BS2} ' BASIC Stamp Directive ' {$PBASIC 2.5} ' PBASIC Directive ' -----[noparse][[/noparse] Constants ]---------------------------------------------------------- Negative CON 1 ' Sign - .bit15 of Word variables Positive CON 0 ' -----[noparse][[/noparse] Variables ]---------------------------------------------------------- x VAR Word ' Memsic x-axis measurement y VAR Word ' Memsic y-axis measurement side VAR Word ' trig subroutine variable angle VAR Word ' result angle - degrees sign VAR Bit ' Sign bit ' -----[noparse][[/noparse] Initialization ]----------------------------------------------------- DEBUG CLS ' Clear Debug Terminal ' -----[noparse][[/noparse] Main Routine ]------------------------------------------------------- DO PULSIN 6, 1, x ' x-axis measurement PULSIN 7, 1, y ' y-axis measurement ' Scale and offset x and y-axis values to -127 to 127. x = (x MIN 1875 MAX 3125) - 1875 ** 13369 - 127 y = (y MIN 1875 MAX 3125) - 1875 ** 13369 - 127 [b][u]IF x << 010 THEN HIGH 5 'Here is my little addon <<<<<<~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~[/b][/u] ' Calculate and display Arcsine of x-axis measurement. side = x GOSUB Arcsine DEBUG HOME, "x tilt angle = ", CLREOL, SDEC3 angle, CR ' Calculate and display Arcsine of y-axis measurement. side = y GOSUB Arcsine DEBUG "y tilt angle = ", CLREOL, SDEC3 angle PAUSE 50 ' Pause 1/20 second LOOP ' Repeat DO...LOOP ' -----[noparse][[/noparse] Subroutine - Arcsine ]----------------------------------------------- ' This subroutine calculates arcsine based on the y coordinate on a circle ' of radius 127. Set the side variable equal to your y coordinate before ' calling this subroutine. Arcsine: ' Inverse sine subroutine GOSUB Arccosine ' Get inverse cosine angle = 90 - angle ' sin(angle) = cos(90 - angle) RETURN ' -----[noparse][[/noparse] Subroutine - Arccosine ]--------------------------------------------- ' This subroutine calculates arccosine based on the x coordinate on a circle ' of radius 127. Set the side variable equal to your x coordinate before ' calling this subroutine. Arccosine: ' Inverse cosine subroutine sign = side.BIT15 ' Save sign of side side = ABS(side) ' Evaluate positive side angle = 63 - (side / 2) ' Initial angle approximation DO ' Successive approximation loop IF (COS angle <= side) THEN EXIT ' Done when COS angle <= side angle = angle + 1 ' Keep increasing angle LOOP angle = angle */ 361 ' Convert brads to degrees IF sign = Negative THEN angle = 180 - angle' Adjust if sign is negative. RETURN
"<<" means shift left.
Bean.
www.iElectronicDesigns.com
I think i found it, the angle you want has to be twice that in real life, so, if i wanted 10 degrees, then led light up, I would have to put in a 20 in the code... (don't know why)
new code:
Post Edited (Ctrl.Alt.De1337ed) : 3/28/2008 7:37:47 PM GMT
