Schematic for OEM BS2-SX and OEM BS2-E
Please help, as i think i fried my BS2-SX. OK i spent about a week testing a proto board, that i built just to have the BS2-SX short it out upon insertion. The circuit is built exactly as the "BASIC Stamp 2sx Change Notice For Interpreter Chip Users" shows. What the "H""E" double hockey sticks is going on. Do I Have a bad chip?
It's most likely that the problem is with your proto board, and not with the Stamp. I've been on these forums since the BS-2SX was introduced, and I've never heard of any of them shorting out anything by themselves. The Stamp chips are rock solid, and always has been.
Bruce Bates
Involvement and committment can be best understood by looking at a plate of ham and eggs. The chicken was involved, but the pig was committed. ANON
I thought the same thing. I retraced every thing to do with the 5V supply and every thing is the way it should be. at least according to my documents. Also let me clarify this is an OEM project. Using the individual components not a module.
This is the schematic I use to wire up my project as its the only one I could find. parallax.com/Portals/0/Downloads/docs/prod/schem/BASIC-Stamp-2sx-Change-Notice-For-Interpreter-Chip-Users.pdf
Are these correct for the OEM BS2-SX interpiter chip. I am using the DIP package. I want to verify that this is the proper circuit before attempting to use another chip.
OK, well that explains it guess i need to contact parallax. Yes i did connect my chip to the circuit. well its probably junk now. Your link brings up a question if this is the same chip i have why did mine cost 12.95? when the one in your link was 2.79. whats up with that. well any ways, I'll change my circuit and see what happens. thanks
In regards to the datasheet it is for the SX28 processor chip itself. It doesn't have the Stamp Interpreter included. It is programmed in assembly code or with a special BASIC compiler called SX/B. It also requires a special programming adapter called the SX-Key or SX-Blitz to program the flash in the chip.
If you have a large volume then you might want to get used to SX/B and try programming the SX chips directly as you can save some money on your project.
Cool thanks just wish they would have included that on the Chips Page.
