Parallax USB-Servo not working anymore
just trying to diagnose what might have changed since I last had it plugged in last week:
knows working servos (they were hooked up the Parallax before) don't move.
New micro (8g esky) servos don't move.
I MM'd the 5V input and my testing PSU is supplying 5.23V.
uninstalled the PSCI, removed the com3 port, etc.
restart, reinstall, no change.
I do have an LED-wiz now, but that wasn't plugged in yet.
When I plug the LED-wiz in it does NOT use the same Com3 port, I thought it might be grabbing the address.
I plugged a Flylight (5V EL wire) into a servo pin and it lights up, so there is voltage.
So, to eliminate other possibilities, what "should" my Com3 settings be?
9600,8, none, 1, none
driver is FTDI dated 5/19/2006, seems like a newer one out, but it worked last week.
anything else to try?
is there a way to diagnose signal issues?
EDIT: tried it on another XP-SP2 system, and it returns the Version number now...must be something with·the LED-wiz install,·queried their tech support to clarity it enumeration, and will report·back for future users.
Post Edited (Dgephri) : 3/28/2008 6:04:42 PM GMT
I'm using XP-SP2 Laptop with Visual Studio 2005 C#.
How are you powering the PSC logic?
As for the Servo power - that is provided from 4 AA batteries (alkaline type).
I use a program I wrote for the mac for my psc usb to help me find endpoints for my costume
Thanks Parallax for delivering such robust hardware - now only if you can help me with my programming skills.....
I wish my other servo controller worked.. I think I burned out the input pin..
and I dont think it can be fixed
Once I moved the physical USB plugs around, it works fine in conjunction will all my other devices.
So for any others having issues hooked to a complicated PC with numerous USB devices and motherboard plugins, try moving each device around to a different physical port...bandwidth and power requirements can get reorganized and get it working. [noparse]:)[/noparse]
