Ti msp430
Does TI's MSP430 have the same capabilities as the Stamp or Propeller chips? I have some of them and didnt know if it was worth trying to make a programmer for them or not.
Bryan
Bryan
Correction: They're 16 bit processors with more memory than the small PICs and the SXs that Parallax uses for the Stamps.· It has more on-chip memory than the Propeller, but is a lot slower and has only one processor.· It's also only 16 bits and has a simpler instruction set (although does have a multiply instruction).· That would put it somewhat "above the Stamps" in capabilities, but well below the Propeller (unless memory is a main concern).
Post Edited (Mike Green) : 3/28/2008 12:02:41 AM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
They do look like very nice chips, because of the intelligent peripherals and 1uA standby, but they are significantly less powerful than the prop. I think they top out at around 16MIPS (and they only have a 20bit design). But, like several other people have said, they have a lot of memory.
CRaig
My system: 1.6 GHz AMD Turion64 X2, 4GB DDR2, 256MB ATI Radeon Graphics card, 15.4" Widescreen HD Screen
I have a duel boot of Ubuntu Linux and Windows Vista. Vista, because it came with the PC, Ubuntu because I like software that works.
"Failure is not an option -- it comes bundled with Windows."
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
Windows for Solitaire
The MSP430 chip is an inexpensive, low power chip which can be good for many applications. I picked up one of the ezMSP430 packages a while ago. I played with the chips some and worked on my C programming skills. I think the MSP430 would make a good co-processor sort of chip or is great for low cost, low power devices.
Certainly it does not compare to the Propeller.
Timothy D. Swieter
www.brilldea.com·- check out the uOLED-IOC, an I/O expansion for the uOLED-96-PROP
www.tdswieter.com
One little spark of imagination is all it takes for an idea to explode
Tracy Allen
www.emesystems.com
This seems to be a big disadvantage when you are trying to design tiny boards.
www.fd.com.my
www.mercedes.com.my
Leon
Timothy D. Swieter
www.tdswieter.com
