flame detection at distance.
Hi folks,
I'm in a class at school where we want to find a candle in an area about 9 x 9 feet square, with 2x4's as the boundaries (so 1.75 inches high "walls"). The only thing I've found online that can detect flame at more length distance costs about 70 or so dollars. We're doing this a very large room with fluorescent lights and 2 story glass walls on opposite sides (an atrium).
I know how to detect at close distances, but is there any other viable way that I could explore where I could make a candle detector at longer distances?
(btw - our fan to blow out this candle is an 8'' oscillating RV fan - runs of of 12 volts 1.2amp/hour battery, and can put out a candle at over 4 feet away.. this is why we want to detect at further distances - to use the capability of our fan.)
Ben R.
Ben R.
The Hammamatsu R2868 UVtron flame detector uses a special UV glass. That is probably the one that retails for over $50.
I wonder if a pyroelectric detector such as those used in motion detectors could work. It would need to be at the focal point of an infrared lens. But it might give a sharp bi-phase pulse as it rotates past a heat source like a candle.
Tracy Allen
www.emesystems.com
You can buy an inexpensive motion detector from wal mart for about ten dollars that will work or Parallax's PIR sensor for the same price. Some people on this forum have said that a PIRs don't work as flame detectors, but they have worked for me.
Drum roll, please:··· FPT540A,··· probably Fairchild,· I Googled it and saw a data sheet online. Again, I found these in my junk drawer in 1994, they·must have·come from a Radio Shack bulk pack, so they weren't expensive as I got them. I used them in a voltage divider arrangement with a series 1M resistor and found they were·the most sensitive ones I had to detect the candle flame. Not sure if they're easily available, but now you have something to hunt.
Post Edited (erco) : 3/27/2008 9:59:39 PM GMT
This has been a great learning experience for me. Just from doing this first robot, I feel like my knowledge on the subject is at 15000 percent of what it was!
have a good one,
Ben
Looked around for these obsolete phototransistors, but I only found one (overpriced) source. Rose at American Micro (973.377.9566) can supply them for $25.14 each.
At that price, I'd wait for a bulk buy on eBay!
We've got a week and a half to get things together, and I'll try to remember to post how it went for us!
Thanks again,
Ben
