Variable's Nibbles Copied Onto Pins
John Kauffman
I am trying to get the Parallax LCD AppMod to work with an SX (Tech Tool). The SX/B help example uses 8 wire bus, but the AppMod is supposed to work on 4 wire bus as well. An earlier post helped with the masking technique.
I built a cable/adaptor that connects equivalent number pins from AppMod header to the SX RB pins.
In the SX/B program the character to display is held in a byte variable named Char as an ASCII value. The LCD AppMod expects to get that a byte across a 4-wire bus (RB.4-RB.7) in two reads: one read for the high nib and then a second read to get the low nib.
I see the masking ·/ swap trick to get the nibbles, but I don't see how to copy that value from the variable onto the four bus pins. It seems there should be a way to set the top four pins of RB to be equal to the masked value in Char. Is the syntax something like the lines that start with ???
Char················ var······ byte
??? LcdBusOut··········· var······ RB.high
Char = %10000001···· ' = 65 = "A"
??? LcdBusOut = Char & $F0 ' put value of Char high nibble into bus pins
PULSOUT LcdEnable, 3 ······· ··········· ' Tell the AppMod to read the data bus
SWAP Char···························· ··········· ' swap low & high nib
??? LcdBusOut = Char & $F0 ' put value of Char low nibble into bus pins
THanks.
THanks.
· SX/B does not have a "Nibble" variable·type.
· You'll need to do it in several steps.
·Bean.
www.iElectronicDesigns.com
Post Edited (Bean (Hitt Consulting)) : 3/26/2008 11:13:54 AM GMT
