Serial connection between basic stamp 1 and hyperterminal using max232
Trying to connect an basic stamp 1 to a pc for serout reading. (data from ping ))) I ·used the connection as stated on page 417 of manual (nul modem type) . im using hyperterminal to readout serial data. This doesn't work. debug works (blue screen shows data)
As a test i· did the ·output·on·pin 7 from·1 to·0 using: high 7 pause 2000 low 7 pause 2000. The level changes on the output, trough the max 232. ie +/- 8V. tryed the SEROUT.bs1 from the·library. Not receiving anything in hyperterminal. Please help. regards
Chris.
Chris.
T2400 and TO2400
That didn't work.
I used to have a nice logic analyser but nowadays i'm a bit blind checking the output signal.
I've ordered a stamp2sx, its in the post. But i hoped to get the stamp1 working as i don't need the power.
regards,
chris.
Hyperterminal received all input. I'll dig into the basic 1 stamp issue, when more time is available and when i've got all the right tools back. I'm sure its solvable.
Anyway, thanks for your kind support.
Chris.
Belgium.
