DS1302 backup power
I have a DS 1302 connected to a BS2. Works great, buzzer buzzes on the hour as its supposed to do.
If i use the battery backup power to the DS1302, AND the BS2 looses power, dont i have to reset
the proper time and date? (because the BS2 will try to reset the time and date from the Pbasic program.)
Thanx
Rick
Thanx
Rick
So you might use an eeprom setting in the BS2 (or a memory location in the DS1302) to indicate the time has already been 'set' accurately, so the BS2 program doesn't require you to enter what the correct time is every time the power goes off and the BS2 resets.
Please post the code that you are using
··Thanks for any·
Sam
rick
' {$STAMP BS2}
'BASIC Stamp II (BS2-IC) Program Listing #1
'* Title: DS1302_1.BS2 Author: Jeff A Martin Date: 5/18/98 *
'* Description: This BASIC Stamp II program interfaces to the Dallas Semi. *
'* DS1302 Real Time Clock (RTC) chip. The date and time is *
'* read and displayed in long and short formats on the debug *
'* screen. *
'* Notes: This program can be modified to fit into a smaller code space. *
'* It is not written as compact as possible to make it more readable *
'* and to demonstrate all the useful functions of the chip. *
'* The DS1302 features seconds, minutes, hours (AM/PM-12/24 modes), *
'* date of month, month, day of week and year time-keeping with *
'* leap year compensation valid up to 2100. Scratchpad RAM memory *
'* (31 bytes), single-byte and multi-byte reads and writes, software *
'* clock-halt, software write-protection, trickle charge and *
'* operation down to 2.0 volts @ 300 nA are other notable features. *
' http://www-eng.lbl.gov/~lafever/Parallax/Source_Code/Application_Kits/DS1302_Real_Time_Clock/DS1302_1.bs2
'Define I/O pins and RTC variables
Clk CON 0
Dta CON 1
RTCCS CON 2
RTCCmd VAR Byte
Value VAR Byte
Seconds VAR Byte
Minutes VAR Byte
Hours VAR Byte
Date VAR Byte
Month VAR Byte
Day VAR Byte
Year VAR Byte
Idx VAR Byte
'Define RTC Command Constants
SecReg CON %00000
MinReg CON %00001
HrsReg CON %00010
DateReg CON %00011
MonReg CON %00100
DayReg CON %00101
YrReg CON %00110
CtrlReg CON %00111
TChgReg CON %01000
BrstReg CON %11111
'Define Days-Of-Week, Months and AM/PM text.
'All text is stored in EEPROM with a binary 0 as the end-of-text character
Sun DATA "Sun",0
Mon DATA "Mon",0
Tue DATA "Tues",0
Wed DATA "Wednes",0
Thu DATA "Thurs",0
Fri DATA "Fri",0
Sat DATA "Satur",0
Jan DATA "January",0
Feb DATA "February",0
Mar DATA "March",0
Apr DATA "April",0
May DATA "May",0
Jun DATA "June",0
Jul DATA "July",0
Aug DATA "August",0
Sep DATA "September",0
Oct DATA "October",0
Nov DATA "November",0
Dcm DATA "December",0
AM DATA " AM",0
PM DATA " PM",0
'Set I/O pin states and directions
OUTS = %0000000000000000 'All logic low
DIRS = %0000000000000111 'I/O 0,1 and 2 are output, rest are input
Initialize:
'Set Time and Date to 05/18/98 - 3:00 PM
'NOTE: Date must be set only once for every power-up of DS1302 chip.
Day = $06 'Friday ENTER A NUMBER HERe
Month = $03 'July
Date = $16 '06
Year = $08 '2007
Hours = $09 '09 AM (in 24-hour mode)
Minutes = $33
Seconds = $00
GOSUB SetTimeAndDate
Loop:
'Read out all date and time values and display them in two formats on
'the debug screen.
GOSUB ReadRTCBurst
'DEBUG HOME,"LONG FORMAT DATE AND TIME:",CR
'GOSUB PrintLongDate
GOSUB Print12HourTime
'DEBUG CR,CR,"SHORT FORMAT DATE AND TIME:",CR
'GOSUB PrintShortDate
GOSUB Checkit
'DEBUG CLS
'GOSUB Print24HourTime
'DEBUG CR
GOTO Loop
Checkit:
' Lawn Sprinkler On / Off code
'IF (Month = $07 AND Date = $06 AND Hours = $09 AND Minutes = $08) THEN SprinklerOn
'IF (Month = $07 AND Date = $06 AND Hours = $09 AND Minutes = $15)THEN SprinklerOff
'IF (Month = $07 AND Date = $11 AND Hours = $18 AND Minutes = $00) THEN SprinklerOn
'IF (Month = $07 AND Date = $11 AND Hours = $18 AND Minutes = $30)THEN SprinklerOff
'IF (Hours = $18 AND Minutes = $55) THEN SprinklerOn
'IF (Hours = $18 AND Minutes = $56)THEN SprinklerOff
' Exterior Christamas Lights
'IF (Hours = $16 AND Minutes = $30) THEN SprinklerOn
'IF (Hours = $23 AND Minutes = $58)THEN SprinklerOff
'IF (Hours = $17 AND Minutes = $00) THEN SprinklerOn
'IF (Hours = $17 AND Minutes = $20)THEN SprinklerOff
my current code starts here
HIGH 14 'LED on pin 14
PAUSE 300
LOW 14
PAUSE 300
IF ( Minutes = $00 AND Seconds = $00 ) THEN Sound1
IF ( Minutes = $15 OR Minutes = $30 OR Minutes = $45 AND Seconds = $00 ) THEN Sound2
RETURN
Sound1:
FREQOUT 9, 1500, 2000
RETURN
Sound2:
RETURN
SprinklerOn:
DEBUG CLS
DEBUG " Sprinkler On "
DEBUG CR
HIGH 15 'pin15 high as output
SLEEP 1
RETURN
SprinklerOFF:
DEBUG CLS
DEBUG " Sprinkler Off"
DEBUG CR
LOW 15 'pin15 low as output
SLEEP 1
RETURN
'==================== DS1302 Real-Time Clock Subroutines ===================
PrintLongDate:
'Print long date format on debug screen
LOOKUP Day-1,[noparse][[/noparse]Sun,Mon,Tue,Wed,Thu,Fri,Sat],Idx
GOSUB PrintIt
DEBUG "day, "
LOOKUP Month-1,[noparse][[/noparse]Jan,Feb,Mar,Apr,May,Jun,Jul,Aug,Sep,Oct,Nov,Dcm],Idx
GOSUB PrintIt
'NOTE: The following line prints the proper 4-digit year for the years
'1990 through 2089
DEBUG " ",HEX2 Date,", ",DEC2 20-(Year/90),HEX2 Year, CR
RETURN
PrintShortDate:
'Print short date format on debug screen
DEBUG HEX2 Month,"/",HEX2 Date,"/",HEX2 Year, CR
RETURN
Print12HourTime:
'Print 12-hour time format on debug screen
'NOTE: The DS1302 has 12 and 24 hour time-keeping modes (bit 7 of HrsReg
'sets 12/24 mode and bit 5 indicates AM/PM or 20+ hours). For purposes
'of this example, we're using 24 hour mode only, and converting it to
'12-hour in the next two lines below.
DEBUG DEC2 12-(24-(Hours.HIGHNIB*10+Hours.LOWNIB)//12),":",HEX2 Minutes,":",HEX2 Seconds
LOOKUP Hours/$12,[noparse][[/noparse]AM,PM],Idx
GOSUB PrintIt
RETURN
Print24HourTime:
'Print 24-hour time format on debug screen
DEBUG HEX2 Hours,":",HEX2 Minutes,":",HEX2 Seconds
RETURN
PrintIt:
'Prints zero (0) terminated text from EEPROM
READ Idx,Value 'Get next character
IF Value = 0 THEN Finished 'Make sure it's not a binary 0
DEBUG Value 'Display it on screen
Idx = Idx + 1
GOTO PrintIt
Finished:
RETURN
WriteRTCRAM:
'Write to DS1302 RAM Register
HIGH RTCCS
SHIFTOUT Dta, Clk, LSBFIRST, [noparse][[/noparse]%0\1,RTCCmd\5,%11\2,Value]
LOW RTCCS
RETURN
WriteRTC:
'Write to DS1302
HIGH RTCCS
SHIFTOUT Dta, Clk, LSBFIRST, [noparse][[/noparse]%0\1,RTCCmd\5,%10\2,Value]
LOW RTCCS
RETURN
ReadRTCBurst:
'Read all time-keeping registers in one burst
HIGH RTCCS
SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,BrstReg\5,%10\2]
SHIFTIN DTA, Clk, LSBPRE, [noparse][[/noparse]Seconds,Minutes,Hours,Date,Month,Day,Year]
LOW RTCCS
RETURN
ReadRTCRAM:
'Read DS1302 RAM Register
HIGH RTCCS
SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,RTCCmd\5,%11\2]
SHIFTIN DTA, Clk, LSBPRE, [noparse][[/noparse]Value]
LOW RTCCS
RETURN
SetTimeAndDate:
'Write time values into all time-keeping registers, being sure to clear
'the write-protect bit in CtrlReg before the write, and set the
'write-protect bit after the write
FOR Idx = 0 TO 8
LOOKUP Idx,[noparse][[/noparse]0,Seconds,Minutes,Hours,Date,Month,Day,Year,128],Value
LOOKUP Idx,[noparse][[/noparse]CtrlReg, SecReg, MinReg, HrsReg, DateReg, MonReg, DayReg, YrReg, CtrlReg],RTCCmd
GOSUB WriteRTC
NEXT
RETURN
If you do not want the time to reset when you turn power back
ON to the Basic Stamp then " ' "·comment these line out
That should take care the problem of resetting the clock
Initialize:
This will run every time you power up the Basic Stamp from a power loss
unless you do this to this routine
·'·Day = $06 'Friday ENTER A NUMBER HERE
·' Month = $03 'July
·' Date = $16 '06
·' Year = $08 '2007
·' Hours = $09 '09 AM (in 24-hour mode)
·' Minutes = $33
·' Seconds = $00
·' GOSUB SetTimeAndDate
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 3/26/2008 8:57:05 PM GMT
I could do a·once through loop, but if power is lost, then it will run the
once through loop and reset the time.
Thanx
Rick·
RickM
You·ONLY need this routine if you lose power·only to the DS1302 Time Chip
This·NOT need if you only lose Power to the Basic Stamp
· Month = $03 'July
· Date = $16 '06
· Year = $08 '2007
· Hours = $09 '09 AM (in 24-hour mode)
· Minutes = $33
· Seconds = $00
· GOSUB SetTimeAndDate
I initially set the time and date.
If you have to reset the Time And Date then you will have to UN comment
These line above And load the Basic Stamp One Time
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 3/27/2008 2:33:40 PM GMT
http://forums.parallax.com/showthread.php?p=552892
it will igore this loop until a button is pressed (and use the time from the DS1302 )
Is this correct?
Thanx in advance
Rick
Start:
DO ' DEBUG Menu
DEBUG CLS ' Clear The DEBUG Screen
DEBUG CRSRXY, 0, 0, "Press 1 to Set Date/Time.", CR
DEBUG CRSRXY, 6, 1, "2 to Display Date/Time.", CR
DEBUG CRSRXY, 6, 2, "3 to Set/Read DS1302 RAM.", CR
DEBUG CRSRXY, 6, 4, "RESET Stamp to return to menu.", CR
DEBUGIN DEC1 work ' Get 1 Number
IF work = 1 THEN
GOSUB Set_Mode
GOSUB Set_Time
ELSEIF work = 2 THEN
DO
GOSUB Get_Time ' Get The Current Date/Time
GOSUB Show_Time ' Display It
LOOP
ELSEIF work = 3 THEN
GOSUB RAM_Mode
ENDIF
LOOP
If your code doesn’t have a facility to set the date time in it on the fly then you should run a different program to set the time before downloading the main program. The main program should not be forcing the time to a set value each time you run it.
