from which robot i have to start so as to gain good knowledge ??? — Parallax Forums
DimitrrisDimitrris Posts: 7
edited 2008-03-26 16:53 in Robotics
Hallo to everyone. I am new member so i have some questions. First of all , i would like to ask from which robot i have to start so as to gain good knowledge ???·Secondally,· how much do i have to pay for having the robot kit send in Greece??? At last , how can i contact greek parallax representative ??
THX FOR UR TIME ,,
[noparse][[/noparse]Moderator Added Subject]
Post Edited By Moderator (Chris Savage (Parallax)) : 4/1/2008 5:06:46 PM GMT
    edited 2008-03-24 18:22
    An excellent learning robot is the BOEBOT (www.parallax.com/tabid/411/Default.aspx). You can download the manuals here www.parallax.com/tabid/535/Default.aspx. Here's the page with the European distributors: www.parallax.com/Default.aspx?tabid=492. Perhaps someone else knows a distributor in Greece.
  • DimitrrisDimitrris Posts: 7
    edited 2008-03-25 18:48
    What's the difference between Boe-Bot for Microsoft Robotics Studio and Boe-Bot with Usb or serial????smilewinkgrin.gif
    edited 2008-03-25 18:56
    BOE-Bot for Robotics Studio requires a copy of Robotics Studio on a PC to work. The BOE-Bot is made into an "output device" for the Robotics Studio.
    The BOE-Bot with Serial lets you program the BS2 module on the BOE-Bot to do what you want to do. I believe it also comes with quite a few experiments to do.
    If you have a computer without a serial port, you can purchase (for $30 or so) a USB to Serial converter that will work with the BOE-Bot Serial version. Or, you can purchase the BOE-Bot with its own on-board USB to Serial adapter -- the separate adapter is more flexible, but the on-board adapter has less pieces to keep track of.
    I think the Robotics Studio uses a blue-tooth adapter for the PC to talk to the BOE-Bot.
    edited 2008-03-25 19:09
    My PC has bluetooth adpter and Usb port which is better for me??
  • WhitWhit Posts: 4,194
    If you are just starting, I'd get the BOE-Bot with USB. You can always add the Bluetooth Adapter for Microsoft Robotics Studio later.
    Whit+
