Master Reset
I'm sure that you have seen those devices that allow you to do a master reset.· When you reset them they delete all the information that you stored and reset the initial set-up where they may have asked some questions to set the device up for the user.
Is this type of reset done with hardware, software or both?· ·Is it possible to have this type of reset in code only or do you have to load it from another eeprom maybe?
Thanks for your time.
That would probably require flashing...
What device are you referring to?
