Making your own PCB using laserpcb
What do you guys think about this product from www.laserpcb.com/ to make your own PCB? Essentially the process is to print your circuit on copper foil that has self-adhesive backing. You use a once thru laser printer to lay down the resist (in conjunction with their "gel") then you peel off the copper, stick it on FR4 board, and etch it as usual. Only constraint, it seems is you can go above 550 deg F on your solder iron or else the trace becomes de-laminated. I think it's a cool product and was going to give it a try....
Bad spellers of the world untie!
Post Edited (mojorizing) : 3/23/2008 6:39:53 PM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
BTW, that copper foil's gotta be brutal on the paper feed mechanism. I wouldn't use an expensive printer for this.
Leon
Post Edited (Leon) : 3/24/2008 11:18:06 AM GMT
