Ethernet on Hydra
It's pretty easy to get Ethernet on the Hydra. All you need is a Microchip's ENC28J60 board, from sparkfun $35, and some means of connecting it to a Hydra addon card. I used some veroboard and a break-away connector. In fact, I put two female connectors on top of each other to raise the board enoaugh so the Ethernet connector fits between the cart and the board (see pics).
Pins I used:
IO4 -> CS
IO5 -> SCK (SPI CLOCK)
NETTX -> MOSI (Master Out, Slave In)
NETRX -> MISO (Master In, Slave Out)
Of course, 3.3V & ground must b e connected. The breakout board has a pullup for /RESET, so it can be left floating.
The SD card may still be used in SPI mode, since in this configuration, none of the pins needed are used.
Of course, TVIRC runs on Hydra [noparse]:)[/noparse]. The VGA client won't run, because IO 4&5 pins are used for the ethernet and they'd be needed to generate VGA too.
Links:
SparkFun product page: www.sparkfun.com/commerce/product_info.php?products_id=765
Breakout board pinout: www.olimex.com/dev/images/enc28j60-sch.gif
TVIRC client: http://forums.parallax.com/showthread.php?p=716355
PropTCP TCP/IP stack: code.google.com/p/proptcp/
Pins I used:
IO4 -> CS
Links:
Anyway, very cool integration of parts to get something to work. Make a little server of somekind, give us the IP address, so we can pull the page or something cool like sign a guest list and it remembers it.
Andre'
Andre'
And the hardware should have a sticker that tells what kind of DC it wants... I had to google for that, the results said it wants +5V, but then I found the transformer that came with it, and it was 3.3V...
I need to setup my video capture card so I can do some of that myself.
Didn't someone here create a prop screen grabber a while back?
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
Lol : ) I think you mean this http://forums.parallax.com/showthread.php?p=657569 , no video cap from NTSC in, but dumping of display buffers. If you find something else for grabbing a screen using a prop, please let me know too
