need help Using hb_25 motor controller with parallax servo controller usb,
I'm using the parallax servo software, with the parallax 16 usb servo controller, I have two servos that work just fine with it, then I'm using the hb-25 to hook a 12v motor to the system, but I cant seem to get it to work. the motor is a 12v 2 amp motor with gear box,
I have the signal from the servo controller running the the motor hb-25, I have 12v 2amp, running to the bb 25, and then pos and neg wires running to the motor. but the motor isn't getting a signal gtom the motor controller. any advice? I need to get this up and running today.
thank you
Jason MIller
thank you
Jason MIller
- Stephen
so from the 6v servo controller I have signal and ground running, no power, to the motor controller, then I have 12v 2 amp power running to the power in prongs on the motor controller, then I have power and ground, or + amd - running to the motor which is a servo city gear motor Torque of 55 inch pounds.
