Can a Basic Stamp Run on 6v?
Hey,
Sorry if this question is easily found in the documentation, but I am having trouble understanding some of the technical stuff. I have a contest I am entering, and would like to use the Basic Stamp as the "brain" of my car. However, we are limited to 4 1.5v batteries, or 6v. Would I be able to run my Basic Stamp Homework Board (which asks for a 9v battery) on 6v, and drive a continuous rotation servo with it? Thanks for the help, I am really tight on time and can't afford to spend too much time experimenting around. [noparse]:([/noparse]
Thank You,
Bridger Maxwell
Thank You,
Bridger Maxwell
I am 1010, so be surprised!
Post Edited (cdesigns) : 3/21/2008 8:43:14 PM GMT
Another option with 4 cells, albeit pricey, is a set of Energizer e2 L91 1.5 volt lithium cells.
Terry of Hitt consulting has a five AA battery holder for sale that could be used for set of 5 NiMH AAs that as cdesigns suggested.
Tracy Allen
www.emesystems.com
Hook your servos directly to the battery +6 volts, not through the dropping diodes. Common negative ground (Vss) for everybody.
AA cell voltage will fade quickly and you'll have to change them a lot if you require consistent performance. Suggest you use C cells if possible, they'll last much longer. D cells are even better, but much heavier.
Tracy Allen
www.emesystems.com
Look in the "miscellaneous stuff" section.
Chris I.
