Unable to write to 64K EEPROM Upper Half
![william chan](https://forums.parallax.com/uploads/userpics/RBTCEMRWP85K/nQFR9OII9OM33.jpg)
Help !
When I write to an address higher than 32K in a 24C512 eeprom,
like below,
OBJ
i2c : "basic_i2c_driver"
eeprom.WriteLong(i2c#bootpin,i2c#eeprom,32768,data)
it actually overwrites the Propeller's own program.
This happens everytime.
Then the Propeller cannot be reset since it's own program is corrupted.
What could be wrong?
www.fd.com.my
www.mercedes.com.my
like below,
OBJ
www.fd.com.my
www.mercedes.com.my
Everything else works with this eeprom.
Have you tested the basic_i2c_driver with this eeprom before?
www.fd.com.my
www.mercedes.com.my
There's nothing in the code that would cause addresses to wraparound at 32K. The only mechanism for
what you're reporting would be a substitution of a 32K byte EEPROM for the expected 64K byte EEPROM.
It was a wrong chip that was plugged in.
The basic_i2c_driver now works with the correct 24LC512 chip.
www.fd.com.my
www.mercedes.com.my
