No Basic stamp found
When trying to load code onto the basic stamp I receive this message. "No basic stamp found".
I'm using a BS2e controller.
USB to Serial Device. I have turned off Fifo
I have checked the power supply, DC adaptor ~ 9v
Both loopback and echo are "yes"
What should I try next?
Is the LED lighting when you switch the power on? - If not the 9Vdc may be reverse polarity.
Is the USB comms link LED flashing when you try to download a program form PC into the STAMP? If not maybe a cable fault.
IF both of the above are correct one last check from the manual is - check the STAMP is installed the right way?
I have checked the voltage across the Vin and Vss pins and it is correct.
The USB is working properly, it receives and echo and loopback from the serial port.
Post Edited (Chris Savage (Parallax)) : 3/21/2008 3:26:06 PM GMT
Exact same problem -
I'm using a Sabrent SBT-USC1K
It was uber cheap, and now I'm starting to think its the problem.
(Sorry to thread hijack, again!)
